Александр Бокарёв
- 12 Ноя 2019
- 21,002
- 9,534
- 382
und sagen Sie, wo sind ihre Qts =0,38 und Resonansfrequens = 25Hz? Traum- und Leben.
All clear. Just oaky suspensions. Change to polyurethane foam, knead, soak. 30 Hz will be a reality.
Recently I changed the suspensions to 75GDN-3. Received 25 Hz and 26.5 Hz, Q factor about 0.3, VAS about 130 liters. Suspensions are polyurethane foam, gray, according to unverified data, Polish.у вас все еще есть подходящие подвески для колонок?
do you have them refoaming or reconen?Recently I changed the suspensions to 75GDN-3. Received 25 Hz and 26.5 Hz, Q factor about 0.3, VAS about 130 liters. Suspensions are polyurethane foam, gray, according to unverified data, Polish.
75 ГДН-3
The speakers are installed back into a friend's system.do you have them refoaming or reconen?
the data sounds almost perfect!
I don't want to buy it.The speakers are installed back into a friend's system.
I only replaced the broken polyurethane foam suspension. The centering washer will outlive meI don't want to buy it.
if i want to do the same, what exactly did you do, just swapped the bead or also the spider?
now i feel like learning more about itI think yes.
no, i haven't done that yet, i will edit the rubber surrounds with balistol for the first few attempts.I think yes.
Try to compare the stiffness of the centering washer and the rubber suspension by bending with your finger. There are also oak washers. Did you measure the rest of the speakers?
I had 2 copies of the 75GDN-1L-4, rubber, with resonances of 25 and 30 Hz upon purchase. After a long break, the resonances rose to 38 and 32 Hz, respectively. After warming up and cutting out the sectors from the centering washer, the frequencies dropped to 27.5 and 29.5 Hz, respectively. The first has a rigid centering washer, the second has a rigid suspension!
There is a scatter of parameters from the factory.
If I understand correctly, you have problems either with the location of the systems in the room, or with the measurement process.да, верно, но, в конце концов, я не хочу сидеть на месте слушателя перед динамиком
Draw your "indoor catastrophe". It may be enough to successfully position only two bass reflexes for good sound in the listening area.The room is a catastrophe! That's why I want to set up as many woofers as possible to regulate it digitally.
The main speakers look exactly like this.
but in the sweetspot I get felt a clean sound .. felling ..
but not really real and clean loud data
Und das ist meine Melomanchildkröte.Das is meine Vinil-Meloman-Katze
У 75ГДН-1 и 75ГДН-3 медь. Красивая, аж красная, советская)Скажите пожалуйста, катушка у 75 ГДН на каком каркасе намотана, медь или бумага?
Прислали фото 30ГД-1-25, там медь:
В то же время пишут, что у 75 ГДН так же медь:
Пропал наш немецкий друг...Посмотреть вложение 11823Посмотреть вложение 11824Посмотреть вложение 11825Посмотреть вложение 11826Посмотреть вложение 11828
as you can see, there is not much that can be done .. i would have to tear out a wall and pull up a new one in a different place
Вы забыли про 25ГД-41, 25ГД-42, 50ГДН3-4, они как бы то же "детишки" 8гд-1-25, только каркасы катушек у них алюминиевые.Бумага на каркасе катушки только у прародителя. 8ГД-1-25 "RRR". У всех остальных его дочек и сыночков: 30 ГД-ХХ и 75 ГДН-ХХ каркас медный.
